G'day chaps, while the rain is lashing down and i have not ventured out into my garage to still try and find some sort of organization although i am getting there i wondered if there is a contortionist out there not just to get in the back of my 109 camper to take out two batteries that need a clean up check and trickle charge but also come up with a better idea of getting at my eberspacher
Unfortunately when i first fitted the sink draining/board and double burner from a caravan i decided to mount my then working eberspacer underneath the draining board and boxed it in using self tappers shortened with the point taken off and with in some occasions spy clips.
Unfortunately i am not so bendy now so need to make an access point from the outside of the body a bit bigger than the eberspacer itself so i can at least take it out get to the flexy pipes that run to the cab area and one to the stainless dog bowl that acts as a collector to the rear of the body that has a vent to open and shut so the cab warms up quicker before setting off.
I have no spare ambulance locker doors and i don't think a standard locker top would be big enough however if anyone has a Gerry can holder that fits in the side of the truck i think this will do
any ideas advice would be gratefully received also if you need pictures to give you ideas like i said a contortionist to get in the back would be good
and you think i am joking. Catch you later. R-Rose
