Hello, I haven't been on this site for a long time.
KPE 614 K was, on the 6pot site 'The original' bought almost derelict and rebuilt to a useable state. It is till going but in need of much TLC as I use it as an almost daily driver and towing a small trailer on an irregular 200ml round trip commute to work at the far end of the Lleyn peninsular. She is a '72 Carawagon Continental Ultimate. With a 2.5 N/A diesel and a 4 cyl bulkhead. Inside is mostly standard and original except that the 2 burner bottle pressure stove is now inside the back door to keep the draughts off it when the door is open. I sleep in it occasionally when the work site is acceptable. I will register her when I take pics of lower definition .
Hello from Cheshire
Re: Hello from Cheshire
Hi dpaz.
Glad you found your way back and are putting your camper to good use. Hope you find a good set of rear springs, which might be worth the question on this forum too
