Good afternoon Ladies & Gentlemen
My Dormobile is missing the shelving to the right of the wardrobe. May I ask for some detailed images of the shelving & dimensions if possible.
I would like to get something made up that is as near original as possible.
I have used Google to see plenty of shots into the vehicle, showing the wardrobe side of the selves, but very few actually from inside the vehicle looking outwards towards the (ideally empty) shelves.
Any images / dimensions / indication of fixing points, etc would be appreciated.
Shelf Unit - Images & Dimensions
Re: Shelf Unit - Images & Dimensions
Hi Mark
Will try and remember to get the tape out tomorrow. The wardrobe did evolve throughout production. Can you post a picture of your wardrobe? Are there any marks to indicate the shelves have been removed? I put my selves in slightly different place to the original to allow a nato water jerry can to fit on the bottom shelve,
As for paint, they were originally painted with enamel paint which was baked. I have brush painted units with Hammerite and also sprayed units with Hammerite. The spray finish is much more like the original paint finish.
Thank you Mick for your reply.
Hopefully you can see that I appear to be missing:
[1] The back of the wardrobe. From my research it appears to be a separate panel to the shelving.
[2] The shelving itself.
I would appreciate being advised as to what constitutes a "period piece" so it is all in keeping. The wardrobe looks original (from what I can see). I will roughly key the red hammerite & return it to the silver (by brush) that it should be after any rust has been treated.
Thank you for your help.
An example image is here:
The full "wardrobe subset is here (I hope)
http://s1032.photobucket.com/user/mark_ ... t=3&page=1
Hi Mark
Your wardrobe is the early version, like top one on Teri Anne's site, and only has a shelve for the top bottle. There is a good picture of the shelf half way down the page. Mine is a latter unit like the one in the pictures further down.
As for the back plate, that is just a flat piece of steel plate cut to fit. There were no shelves in the wardrobe, just the hanging rail.
Thank you Mick for the information. I now have a good idea of what it originally looked like courtesy of your reference to Terri Anne's site
Much appreciated
Much appreciated
