Well, I got a new sheet of marine ply to replace the one I found with a delamination fault!
So, I cut new sides for the Carawagon roof today, then decided to go the whole hog and replace the lot!
So, here's a roofless Carawagon:
(Must get a haircut!!)
Patrick removing the rivets from the hinge to replace the seal:
I've decided to put the original wooden roof rack back on, like Patrick's, as the original sections had been hacked off to fit a metal rack
My slot cutter - to cut slots in the edge of some roof sections for the seal - Patent applied for
All the pieces have now been cut and have had a good drenching of preservative.
Just another couple of drenchings, then 3-4 coats of yacht varnish, and it should all be ready to go back on.
Meanwhile, the Carawagon is looking a bit blue
More to follow
