Dormobile Table
Dormobile Table
What Cheer All
Neither of my 2A Dormobiles has the standard table: clips on passenger side and stored on rear door.
Are there any accurate dimensions and pictures available please to I may manufacture - alternatively, any one have the standard table for sale?
I also do not have the fitting type and accurate locations for clipping to set and door frame: help will be welcomed.
I live in Somerset, and could travel to view and take pictures and measurements if that would be convenient - work permitting?
Many Thanks
jj
Many Thanks
jj
Re: Dormobile Table
Mine is all intact but is in Carlisle... If you can wait until nearer the weekend I will take detailed measurements and pictures? Of course if your work takes you this far up, feel free!!
The door frame clip is remarkably simple but effective!
Re: Dormobile Table
Mick is making a set for me. if you aren't in a hurry, I could ask him to make another set. Do you want to go halves?
Alex
Alex
Re: Dormobile Table
I purchased a new one from Jim at Dormobile as mine was missing, only problem with it was all the fittings had been put on incorrectly
http://www.dormobile.co.uk/pdfs/LRpartsUKEU.pdf
20130514-Dormobile Table-jj
May Thanks All for suggestions.
DabC: Carlile a little far however would really appreciate pics and measurements please, it will give me an indication of the work involved and if beyond my simple facilities. My mail jonjeans@tiscali.co.uk
JeryD: Dormobile factory I can wait out on. I had similarly experience as not all items fitted as original.
Alex, Regarding Mick making table - how much are they?
Thanks again All,
jj
Thanks again All,
jj
Re: Dormobile Table
I have had 4 people ask about tables and making the steel bits shouldn't be that much of a problem. Would anyone want the table top as well? Would have to do a bit of research on what materials are available to make a good copy?
Re: Dormobile Table
Thanks for this Mick. Naturally dependent on cost - and I presumed that the table top would be part of the table - but not having one - I don't know the construction and fittings. - jj
