re-classification of v5
Anyone any idea of how much trauma and scrutiny is involved in changing the v5 classification on a v5?
I would like to change my project (blue dormobile) to motor caravan as per my green dormobile
Re: re-classification of v5
It does look like you can change it on the V5, section 7, but perhaps it might be worth a phone call to DVLA? They should be able to tell you if it's just a matter of changing it and sending it to them, or if they need any other proof
Out of our four Carawagons here, only one is listed as Motor Caravan - the others are all Light 4x4 Utility
I wonder if it's a case of whether it was converted before registration or after
Does it have an effect on AA type recovery services, or is that only affected by the weight?
my v5 for my carawagon, section 4 (D.1 Make) says LANDROVER CARAWAGON and D.5 Body type LIGHT 4x4 UTILITY . is this what all carawagon v5 say
hi
my log book records D.1 landrover D.5 light 4x4 utility D.4 2 axle-rigid body
no mention of carawagon.the only reason i can think is some of the landrover
supplying dealers registered the vehicles as light 4x4 utility before sending them
to carawagon and carawagon registered them as carawagon.
regards
phillip
regards
phillip
My 1972 Carawagon (project):
D1 Make LAND ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
D5 Body Type MOTOR CARAVAN
My 1966 Carawagon (currently on the road):
D1 Make LAND ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
D5 Body Type LIGHT 4X4 UTILITY
My future 1958 Carawagon is, of course just a LWB as I'm swapping the pickup
for the Carawagon body I bought from Truro.
However, the details are:
D1 Make ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
I'll probably send the V5 back for both of the ones listed as Light 4x4 Utility to get them changed to Motor Caravan at some time
D1 Make LAND ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
D1 Make LAND ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
D1 Make ROVER
D2 Type (blank)
D3 Model (blank)
(no D4 at all)
Holly, my 1972 SIII Carawagon has:
Model: 109" - 4CYL
Body type: MOTOR CARAVAN
Model: 109" - 4CYL
