Rushden Cavalcade last weekend
Posted: Sat May 09, 2015 10:31 pm
Re: Rushden Cavalcade last weekend
Posted: Sun May 10, 2015 5:59 am
by Marque
Well done that man & family. Very taken with the shrunk Bedford Van parked to your left.
I hope your family enjoyed the event.
Posted: Sun May 10, 2015 9:41 am
Yes, very well done Michiel - I know it's been a long time getting ready, but I'm glad you enjoyed your few days away in your Dormobile.
Perhaps you might like to join us at Billing this year, under your own power this time, and camp with us instead of leaving it there as a showpiece (for which we were very grateful
By the way, glad to hear you are pleased with the heater
Where did you fit it? I know one or two others who bought the heaters from me for a Dormobile and have asked for advice on the best place.
Not having access to a Dormobile, I couldn't really help them.
Posted: Sun May 10, 2015 6:24 pm
by AntMan232
I was flicking through those photos, and i'm interested by your setup for seatbelts in the back, it looks like you have an extra steel bit to mount the reel on, and then hooks in the floor for the clip bit? Is the steel bit a standard item, (I guess the nice looking trim panel over it is?), and have you just got a big spreader plate under the floor hooks?
Thanks,
Posted: Sun May 10, 2015 11:55 pm
Robin,
I have post a write up in the technical section with lots of pictures of the heater installation here:
http://www.rms1.co.uk/lrcc/forum/viewto ... f=17&t=935
Posted: Mon May 11, 2015 12:06 am
AntMan232 wrote:I was flicking through those photos, and i'm interested by your setup for seatbelts in the back, it looks like you have an extra steel bit to mount the reel on, and then hooks in the floor for the clip bit? Is the steel bit a standard item, (I guess the nice looking trim panel over it is?), and have you just got a big spreader plate under the floor hooks?
Thanks,
Hi Ant,
I have use standard Landrover Defender items for the seatbelts in the rear. The reels are anchored to a metal bracket. These brackets are the standard ones used in the Defenders. They fit exactly the same in the series 2 and 3. I butchered the trim that normal goes around the rear windows. Still need to finish it off in a nicer way, but it is all work in progress.
The bottom of the belt goes onto another standard bracket I bolted to the bracket of the seats. This is not ideal, but I could not find the bars that go under the front of the wheel arch like on the Defender. I know you can buy them, but I want to find cheaper 2nd hand ones. The hooks I bolted through a rib under the floor with a few big washers underneath it. I assumed the rib is enough spreading for the force in case of a collision.
I will post another write up for the seatbelt soon with pictures.
I hope this gives you an idea of how I have done it. Jerry has done the same in his. That's where I got the idea from.
The seatbelt themselves I bought of eblag and they are the exmoor trim ones. They were new, but opened boxes.
Posted: Mon May 11, 2015 10:05 am
Hi Michiel, Looks like fun had by all at the show
On the cabinets I made I put a 20mm aluminium angle around the face of the cupboard, this was to stop them "drooping" with age. It also gives a stronger fixing for the hinges to be fixed through the aluminium. Something you might want to consider.
I find the defender seatbelts work great and are a great improvement, but shutting the curtains can be tricky sometimes.I bolted the seat belt into the sill section to keep it all straight. I've got a plan in mind to finish the plastic trim pieces which will be moulded into a piece behind the curtain tracks
Watch this space .........
Here's a couple of pics of the units "work in progress" You can see the aluminium angle on the painted locker
Posted: Mon May 11, 2015 10:27 am
Thanks for the tips on the cabinets Jerry...
I might just do the angle bit on the big cabinet. It is great by the way that all the plates and cups fit in the big one now.
Still need to make a cutlery drawer under the cooker. I have the tray and the la bits, just needs fitting. Ahhh, so much to do still....
But first sorting the defender out for its imminent MOT next month...
PS... I have to give you the warmest regards from Colin and Rose. They stopped your place a few years ago with their series 3 109 while traveling around Australia. We are in the same local landrover club in Northamptonshire, the ENLROC.
Posted: Tue May 12, 2015 10:46 am
Hi Michiel, Please say hello to Colin + Rose and give them my regards when you see them next
Tell them I still haven't done the engine conversion .....nor finished the house
I can't believe it's nearly three years since they were here, they must be due for their next trip.
Link here for them -
http://colroseoldagetravellers.blogspot.com.au/
