Night heaters?
Posted: Thu Mar 06, 2014 4:02 pm
I'm trying to negotiate with an overseas manufacturer to import a number of one or other of these two Diesel night heaters:
"Webasto" 2kW
Technical Specifications:
Heat Power: 2kW
Fuel: Diesel
Rated Voltage: 12V
Fuel Consumption: 0.12~0.24l per hour
Power Consumption: 14~29W
Working (Environment) Temperature: -40°C~+20°C
Dimensions: 323×120×121 (mm)
Weight: 2.6kg
CE Certified
Full kit including fuel pump, fuel tubing, exhaust pipe, inlet pipe, clips, wiring, control etc.
Automatic air heater with fuel tank
Heat Power: 2.8kw to 4.6kW
Fuel: Diesel
Rated Voltage: 12V
Fuel Consumption: 0.3l to 0.6l/hr
Power consumption: 70W
Dimensions: 550x250x250(mm) (with tank)
Fuel tank: 480x75x200 (mm) 6.7litre
Weight: 16kg
CE Certified
Completely self contained with fuel tank so can be run on red Diesel.
Fuel tank can be removed and Diesel picked up from your vehicle tank.
Initial enquiries are hopeful, provided I can make an order of at least 10 otherwise shipping costs etc. is an issue!
I'm hoping the price of the first type (Webasto clone) will be less than£500 and the second type around £340.
The first is a clone of the Webasto Airtop 2000, (apparently made in the same factory though I can't confirm that!).
The second type is a much more simplified, and so less sophisticated, heater, hence the lower price.
Tuggy has just fitted the second type to his camper SEE HERE
They do come with 12 month warranty, though they will have to be returned to the manufacturer (in China!) if they fail!
I'm also hoping to negotiate a price for some of the common spare parts so hopefully if anything does go wrong, we can fix them here.
EDIT: I have now agreed to cover support and warranty issues here in the UK so no need to send them back to China unless it is totally fubar!
If it all goes to plan, I would set up a test bench here and run each one for an hour or so before sending them on, so I'll be taking on the risk of any which might arrive into the UK faulty
Note that I am not retailing these, I am just getting a bulk order together on others behalf, and so any warranty issues would have to be taken up with the manufacturer, though of course I will try to help.
If anyone is interested in one or other of these, please let me know.
"Webasto" 2kW
Heat Power: 2kW
Fuel: Diesel
Rated Voltage: 12V
Weight: 2.6kg
CE Certified
Fuel: Diesel
Rated Voltage: 12V
Weight: 16kg
CE Certified
