Three way fridge
Re: Three way fridge
Post by RMS » Mon May 20, 2013 6:03 pm
Yes, that's the problem - finding someone who will still empty & refill it with the ammonia mix.
I understand there is someone who will remove all the pipework and replace it with the gubbins from a modern caravan fridge - at a price :stars:
I wonder how easy that is to do without damaging the pipes and joints from the new one :whistle:
Anyone got a modern type caravan fridge they would like to donate for experimental purposes :shrug:
Rob, I've measured the Carawagon fridge at 565mm high, 400mm deep, 380mm wide so a bit smaller than a standard caravan fridge.
Post by RobW » Tue May 21, 2013 9:48 am
If you do try it do so outside, where rubber gloves & safety glasses. Maybe overkill for the modern fridge, but not for the ammonia solution!
