hi
since our w/e in yorkshire,when my
pump tap in the sink froze it has not
worked.
i left it for a while to thaw and now
the pump action works,but no suction.
i can see the spout unscrews but is
the main barrel a sealed unit or will
it come apart.only had a quick look
i await your suggestions
phillip
tap
tap
Re: tap
Hi Phillip,
I think it's the same tap as the one in mine & Patrick's - if so; yes it does come apart but I think it's just a twist/friction fit.
Once you've got it apart, you'll probably find the ball in the bottom of the barrel assembly isn't seating properly, probably due to a foreign body
like a piece of grass we found in Patrick's.
I suppose you could be very unlucky and find that the water in the barrel expanded when it froze, causing some damage - I hope not though
Re: tap
stripped the tap to 8 or 9 pieces,cleaned
could not see anything so rebuilt and refitted
and it works !!!!!
i like it when a plan comes together
phillip
and it works !!!!!
phillip
Re: tap
Great
