So while I'm debating what to do with the gearbox I decided I'd upgrade the seat box. I've removed the original locker from under the passenger seat and made a new box which is big enough to take two batteries and the air con fuses / relays etc. This is a bit of forward planning too for when I fit the 300tdi motor in.
On the driver's side where there was no locker, I've made a shallower box with a removable side to get access to the handbrake.I also want to fit a water tank under this box where the gas bottles were fitted.The original center tray has been retained but slightly modified.
I've made the new boxes out of mdf and have cut and glued aluminium sheet to the exterior faces. The insides will be covered in carpet. I've also made a new top with lids for the seat box, again out of mdf which will be carpeted. This does raise the driving position slightly but I find it better as I'm only little
I did a similar modification to my "Isuzu County" mainly as a soundproofing modification and was surprised how well it worked, so I'm hoping this will quieten down the dormobile too.
Here's a couple of work in progress prototype pics. I'll post a couple of the finished item when it's painted etc.
