Diesel/petrol cab/camper heaters
Post by RMS » Sun Aug 13, 2017 9:39 am
Hi guys,
I'm thinking of making another bulk order of these heaters:
"Webasto" 2kW
Technical Specifications:
Heat Power: 2kW
Fuel: Diesel or petrol (specify on order)
Rated Voltage: 12V
Fuel Consumption: 0.12~0.24l per hour
Power Consumption: 14~29W
Working (Environment) Temperature: -40°C~+20°C
Dimensions: 323×120×121 (mm)
Weight: 2.6kg
CE Certified
Full kit including:
Heater unit
Exhaust pipe
Combustion Inlet pipe
Silicone seal with nuts/washers
Fuel tank pick-up pipe (to straighten and cut to suit)
Fuel filter
Fuel pump
Pump retaining bracket
Rubber fuel pipe joining pieces with clamps
Fuel pipe T splitter (if you don't want to use the pickup pipe)
Fuel pipe
Cable ties
Heater control
Main wiring loom
Fuel pump wiring loom
Manual with installation instructions and user guide
Pipe clamps for exhaust/inlet pipes with screws
Plus, I'm including the ducting kit:
Length of ducting pipe
T piece for ducting
Vent outlet for ducting, with grill
Vent outlet without grill (grill is removed from heater and fitted to this when using ducting
Clamps for ducting
These have proved popular, and this will be the third bulk order.
There have been no problems with any of the units fitted so far, apart from one case of water ingress into the remote controller due to it being fitted below a water leak! which was fixed under warranty.
There's nothing better than being able to get dressed/undressed in a warm vehicle when camping out, in my opinion :gold: and these heaters are perfect for the job.
Some folk with roof tents have fitted them in the vehicle and run a duct up into the tent. A duct could also be run to a ground tent giving you the luxury of warm air while camping.
There have also been a couple fitted to non-campers, as an additional heat source while driving, or even just for sitting in the cab of a working vehicle for eating lunch on a cold, wet day.
I'm hoping the price will be just under £500 if I make another order for at least 10 units.
If anyone is interested please let me know - petrol or Diesel.
A deposit would be required for firm orders, once I have confirmed availability and price.
Jonny72
Re: Diesel/petrol cab/camper heaters
Post by Jonny72 » Fri Sep 01, 2017 1:36 am
Hi Robin - I'd be interested in one - prefer Petrol..
John
1971 Carawagon ‘Ultimate’ (currently undergoing restoration)
Post by RMS » Fri Sep 01, 2017 9:12 am
I've got you on the list John, thanks.
Do you have a deadline for when you want to fit it? Just trying to work out how long I can leave the offer open before I have to place the order.
Post by romanyrose » Fri Sep 01, 2017 10:10 pm
G'day Robin, i think a diesel one would be my preference :wink: , how long have i got to save although i can give you a deposit if i can keep little finger's out of my wallet :whistle: .
Post by RMS » Fri Sep 01, 2017 11:14 pm
romanyrose wrote:G'day Robin, i think a diesel one would be my preference :wink: , how long have i got to save although i can give you a deposit if i can keep little finger's out of my wallet :whistle: .
I think John was wanting to fit his before Winter, but I'll let you know Brad.
A deposit would do - once I've sorted out the order, and I'll put one aside for you :cheers:
Post by romanyrose » Sat Sep 02, 2017 9:34 pm
G'day Robin, thank's matey :bow: it is appreciated very much like always :wink:.
Post by woollen797 » Sun Sep 03, 2017 1:12 pm
Can you put me down for a diesel one please Robin
Cheers Simon
Post by RMS » Sun Sep 03, 2017 4:54 pm
Yes, of course Simon.
Post by woollen797 » Mon Sep 04, 2017 12:33 pm
Cheers.
Still need to find a home for it on the Land Rover though
Jonny72
Post by Jonny72 » Mon Sep 04, 2017 5:35 pm
RMS wrote:I've got you on the list John, thanks.
Hi Robin - I'll fall in with your timings to make sure you get as many interested in a group-buy. Would prefer pre-winter to fit, but I have also got plenty of other jobs to do on her, including adding (vs replacing) new roof seals and an overdrive.
John
