Gas bottles
Re: Gas bottles
Hi all
The gas bottle carrier is still fitted to the back of our Carawagon, but I must admit to never looked at it yet. I have just repaired Hoots 6 pot chassis and that will be going for galvanising soon. I am making several Jerry can holders to go in the pot with the chassis and could make up some bottle carriers if anyone is interested? This is what I do for a living, so there will be a charge.
I will be making a Dormobile bottle rack for Hoots, so let me know if anyone wants one for their Dormobile.
I make Carawagon roof racks, Jerry can holders and tool boxes. Dormobile roof racks. Early and Late Land Rover type Jerry can holders.
Thanks for reminding me to get the bottle rack off the Carawagon.
Re: Gas bottles
It is very early days, but am very taken with JerryD's full bonnet roof rack. Would that be in your scope to produce something like that (for a series 2) that would also allow front Jerry Can Holders to be fitted as well? Any idea of the max permissible weight? I am thinking of using it as a sun deck for my daughter & I. Regrettably I am 95KG at present. Daughter much lighter (4 yo)
Just an enquiry at this stage.
Re: Gas bottles
HI Mark
RE the roof rack, yes I could make one just like that. I have also been thinking of making an extension rack that bolts to the front of my existing racks. This would allow the extension to be removed when not required. I wondered if this extension would be useful for those that might want to fit a roof tent. why fit a roof tent on a Dormobile I hear you ask? The thought came from a conversation with a couple who were considering holidaying with another couple in their Dormobile.
As for what weight can one of my racks carry? Land Rovers limit is 70kgs. My racks are built from the same materials as the leading roof rack manufacturers. These racks are a compromise between weight and strength. If you jump up and down in the middle, the rack will bend. If you spread your weight, you should have no problem. I am 115kgs and I knee on my rack every time we camp to get access to our roof box.
If you want a special rack, I need as much notice as possible as I only do this part time and only galvanise products when I have enough products manufactured to get economies of scale on the galvanising. On average, I galvanise stuff every 9 months.
Re: Gas bottles
My bottle holders are both standard, and accept Calor bottles
Re: Gas bottles
Oh, right, wonder if I had a fat Calor bottle when I tried it in Patrick's
I need to dig one of my holders out to take measurements and photos anyway, so I'll try a Calor bottle in that.
Re: Gas bottles
Thank you Mick. It is early days but i would like to express an interest. Will keep you updated as things develop. I will PM with known and funded requirements.
Please accept my apologies for the thread hijack. Your understanding is appreciated.
M
M
Re: Gas bottles
They are indeed a tight fit on the bottom ring, but no modification was necessary! It had two butane bottles fitted when I got it, one of which it still has (still need to exchange it!). With a bit of foam around the middle, they fit very snugly and tightly with no rattles!
Re: Gas bottles
Ok, I wonder if there were different carriers depending on which bottle you ordered?
I have a 1972 price list which shows two optional extras of Calor Cylinder 10lb and 'Gaz' Cylinder 6lb 2.7kg.
Anyway, a Calor 3.9kg bottle almost fits the carrier I have here - interesting that the base of the Calor 3.9kg bottle I have here measures 7 3/4" - the ring it is supposed to sit in measures 'almost' 7 7/8" inside so the bottle is a very tight fit - as Calum said.
However, the arms of this holder wrap around the Calor bottle nicely.
A Camping Gaz 907 cylinder is quite a bit narrower in the main section, but the base ring is 8" so even more out of sync with the carrier ring.
Hopefully over the weekend I can get up to measure Patrick's - I was pretty sure the 907 cylinder was a good fit in his and that a Calor 3.9kg wouldn't fit, but I'm old and my memory is failing
I'm also pretty sure Patrick's has a hasp/staple arrangement for a padlock and not the threaded rod like this one, which presumably would have had a wing nut?
With Calor 3.9kg cylinder:
With 907 Camping Gaz cylinder:
As it would be attached to chassis rail - dropped for changing cylinder:
Anyway, measurements are as follows:
All steel is 1/8" thick.
Base ring is 7 7/8" inside diameter, 1 1/2" deep
Fixed side is 2 1/2" wide, bottom bend is 1" welded to ring, overall height between bends is 7", top bend is 3"
'Catch' section is 2 1/2" wide, 5" long plus threaded rod, top bend is 3 1/4" long.
This is rivetted to the underneath of the floor, I think.
Hinge tabs are 1 3/4" long, 1" wide
Hinged section is 2 1/2" wide, 11 1/2" long between hinge and top bend. Top bend is 2" long.
This is the section which is rivetted to the chassis rail, with the top bend on top of the chassis rail.
Supporting 'arms' are 1 1/2" wide.
Hope that all makes sense
Re: Gas bottles
Robin, the hanger you have posted looks just like the ones fitted to mine. They were indeed secured by a wing nut - I managed to get one undone and the other sheared so I had to renew one stud (3/8" BSW, luckily very common stuff at work!!). For peace of mind, however, I have used two nuts locked together as I reckon a wing nut will work loose over time. Perhaps an R clip or similar could be used to stop it from undoing? One wing nut under a plain nut is probably easier though.
Re: Gas bottles
Thanks very much for posting those measurements and pictures - they do look identical to the holders which used to be on my Carawagon.
Mick,
Would it be possible to manufacture bottle holders for the Carawagon?
Phil
Mick,
Phil
