Not actually such an issue.Litelandy wrote:I did notice tonight that with the toolbox installed it doesn't leave much room for an overdrive! It'll be a hard choice
I have a Bearmach (Toro) overdrive fitted to Dormy. These come with an oil trap breather chamber as a top cover which I could see would definitely interfere with the bottom of the tool box. My answer was (after some careful measuring) to cut a couple of slots in the bottom of the storage box and bash that part until it was inverted. A couple of small aluminium plates were cut and riveted in to fill the gaps.
Result: - Overdrive fits without interfering with the box and I still have most of the capacity of the larger box (very necessary !).
Also, some self adhesive draft excluder across the back of the storage box seals the gap nicely.
HTH
