Prepping and old LR for winter
Hi folks,
I'm trying to compile a list of ways to make an older Land Rover (Series/Ninety/One Ten) easier to live with in winter, and I'd be grateful for your thoughts. Aside from the usual maintenance checks (antifreeze, tyre choice, underseal against road salt, etc) I'd like to hear any ideas you have for making your vehicles easier to spend time in during a cold spell. I'm also looking for ideas that could be applied to any old utility Land Rover, rather than a description of how to comprehensively convert a Land Rover into a cold weather camper. So, for example...
Anti-condensation ideas
Trim/insulation
Heaters - for air, water, screens, seats...
Lighting and electrics (inside and out)
Anything else?
I'm sure many of your will have spent extended period in your Land Rovers in cold climates, so I'd be interested to hear what you come up with :-)
Theo
Trim/insulation
Anything else?
Theo
Re: Prepping and old LR for winter
Hi Theo,
Well, I can't say much about other Land Rovers as I've not had much experience with winter camping in anything but the Carawagons (except one miserable night on Grewelthorpe Moor in my old LWB, Rex the Rat, with a camping mat and sleeping bag on the floor and gaps between the tub and sides for the snow to blow through
However, I can give one or two pointers from my experience - condensation seems to be a problem for those sleeping in their vehicles, not just from cooking but just from breathing whilst sleeping!
My Carawagon and most others have flocked roofs, so we don't notice condensation. The flock absorbs it then dries out during the daytime.
Flocking was an optional extra, and those with plain alloy roof skins can get a lot of drips, often dripping onto their beds/bedding, unless they leave their roof vents open, one at each end.
Condensation is made worse with a cooker inside the vehicle - if it's gas, petrol or paraffin then for every cc of fuel used, one cc of water vapour is produced. Add in steam from cooking and it can get a bit humid!
One of the Carawagon guys (Steve) who had a plain alloy roof has lined it with a felt-like material similar to flock and that's made a big difference.
So - it helps to cover any exposed metal to help prevent condensation.
We do have winter camps, and it would be miserable trying to get to sleep when it's really cold, so some way of heating the inside of the vehicle is useful, even if it's just for 20 minutes while getting ready for bed, and 10 minutes before you get out of bed in the morning. Then again, I'm a big softy and others 'man-up' and don't bother with heating
It doesn't look like it, but it was almost -10C overnight on this camp!
And this was another chilly night:
And a frosty morning!
There are a few ways to deal with heating. I prefer a Diesel powered air heater (Webasto, Eberspacher etc.) as it gives a dry heat and doesn't cause condensation.
Other similar air heaters can be propane (Whale, Propex) or petrol fueled.
Some folk will put on a gas ring on for a few minutes, but as well as the condensation problems mentioned, there's a real danger of carbon monoxide poisoning with no ventilation, especially if you fall asleep without turning it off!
Some early campers had open catalytic heaters, but again, without adequate ventilation there's a condensation and possible CO problem with those.
It just so happens that I have made a couple of bulk purchases of the Diesel air heaters for our camper friends and have a couple in stock
See HERE))
Someone I know uses a similar heater which heats up water, then pipes it to a narrow radiator under the bed.
One advantage is that you could also fit a calorifier to heat up a store of water, but then you need header tanks, electric pumps etc. and find room for it all. An alternative is to fit it to the engine cooling system and use the heater fan, but then you're heating up the engine block as well
One disadvantage with this type of heater is they are not silent, and although the unit inside is fairly quiet, the exhaust noise can be a little annoying for anyone nearby if they are tenting it!
Lighting - we use LED strip lighting now - less than a tenner on ebay for a 5m length self adhesive, silicone coated (waterproof) strip which can be cut to length from about 1" to the full 5m. Just solder wires to the end once cut and connect through a switch or plug.
I've got a 300mm strip at the cooking end of my Carawagon roof and the original courtesy lamp at the other with an LED festoon bulb.
They provide plenty of light.
Patrick has a full length strip on the inside of his roof, and that is bright!
We've both also got a length stuck on the underside of our awning poles and connected via a plug for outside illumination.
Anyway, that's a start, I hope, and of course, only my experience and opinion.
I'm sure others will be along with their solutions and ideas they use on other vehicles.
Heated wind screens. Makes life much easier & saves scraping the insides.....
I would add that a pre-winter service always helps. Get those drum brakes adjusted while it is still warm(ish) and dry(ish). Sort that knackered front prop uj out before it fails in the snow and ice. Antifreeze and screen wash.
Great advice and some useful details, thanks very much. Love the pictures too - thanks Robin
I've also been hearing good things about heat exchangers (usually with reference to Tdis) and might experiment one day, but obviously it's of limited use in the middle of the night...
Must admit I'm reluctant to line the roof of my 109in. Both hardtop Series vehicles I've owned have had disgusting ceilings, with the mucky remnants of ancient adhesive residue and bits of fluff from previous linings. Obviously there's a right way and a wrong way of applying it, but before going down that route, I thought I'd try a water-repellant spray coating. Has anyone tried this?
Rustoleum do a transparent spray product called NeverWet, which claims to prevent condensation so it might do the trick, but it's expensive: £15 for 1m2...
Also, has anyone tried upgrading their Series door seals to Defender ones? (I believe it involves grinding off a lip around the Series bulkhead?) Much of a difference?
Theo
Theo
Mine are defender ones on the Dormobile. No difference really to new ones
Dont forget the talcum powder on the door rubbers to prevent them from sticking in the freezing cold. Or vaseline, wichever you prefer.
Nice pictures Robin...
Top tip!DrivingDutchman wrote:Dont forget the talcum powder on the door rubbers to prevent them from sticking in the freezing cold. Or vaseline, wichever you prefer.
- Contact:
we have 3 hot water bottles for winter camping which is great until they decide to go play in the nearest stream
