Photobucket are now holding me to ransom !
They changed their terms & conditions and are now demanding money to re-instate 3rd Party hosting.
Once I sort out another photo hosting site I'll reload some photos.
Walter the Dormobile
Re: Walter the Dormobile
- Contact:
I only used Photobucket for the forums so now they have done this I'll no longer use it. I do use Flickr for my photos but sadly all I can add to forums is links to photos instead of the photos themselves.
https://www.flickr.com/photos/21667585@ ... 8665590323
I've started work on my Dormobile again and need to find somewhere to host photos.
Photobucket held me to ransom then I switched to Flickr and they introduced a limit on the number of pictures you could host FOC !!! There are a few pictures left on Flickr.
Anyway, I'm busy installing seatbelts and then moving on to re-covering the seats.
Every time I spend time on the Dormobile I find things missing or broken. One of the rear seats has had the latch cut off so I'll have to make a copy using the other seat.
Today I found rust in the bottom of the B pillar on the passenger side. At some point in the future I'll have to remove the side (A pillar, B pillar & 1/2 C pillar) and either fix the rust or replace with a better panel I have from a Series III Station Wagon. Not looking forward to doing this but one Winter I'll get round to it, the other side probably wants doing as well !
DSCF3388 by Colin Radley, on Flickr
![Image](https://live.staticflickr.com/4046/35321695200_8fe96283d2_c.jpg)
G'day Colin,
I saw a post you put up on the AULRO forum of your dormobile seat trim set from Exmoor. I was wondering what you thought of it and if it included everything you need? I had a feeling they don't provide the material for the underside of the seat?
Litelandy![👍](//twemoji.maxcdn.com/2/svg/1f44d.svg)
Litelandy
Apologies for the very late reply, I haven't been on the forum for a very long time.Litelandy wrote: ↑Mon Apr 06, 2020 3:02 am G'day Colin,
I still haven't got round to fitting the seatcovers, too many projects and not enough time......I'm fairly active on AULRO.
I've been deliberating over the headlining for some time, mine is still there but dirty and damaged.
I recently finished some formers for bending Masonite for the headlining, had to make left & right for the front section and one for the two middle sections. The original hardboard/Masonite was quite thin and looks like it had a textured vinyl already applied, probably in common use in the caravan industry back then.
I found some 3.2mm Masonite locally and downloaded a brochure from Masonite that actually details the permanent bending process.
Tried one of the mid sections at the weekend, wet it down over a few hours then clamped it between the formers. No cracking sounds so promising.....
Left it out in the sun the next day then couldn't wait so had to see if it had worked.
There was some springback so I might try wetting it again and re clamping but an overall success. Now to measure & cut out some Masonite for the front section and see how that works out. The bend at the front is much tighter so it might be a bit harder.
Once finished I need to cover it with some thin vinyl.
Photos are on the AULRO site, when I find a way of free hosting I can put them on here.
The original Silent Gliss curtain rail had been removed from mine and a very dodgy curtain rail fitted in it's place so there are lots of excess holes in the headlining.
Could someone post a picture of where the headlining & Silent Gliss rail join together. Do the screws through the rail hold the headlining to the timber battens ??
Thanks,
