Just come back
Just come back
The bitsa Dormobile has come back
Added pictures of both the doner vehicles for comparison
Re: Just come back
Looking nice Alex
Re: Just come back
Hmm, these photos look familiar... All these forums and facebook pages, can't keep up with it! I shall say it again though, it looks very nice .
Ant
Ant
1965 Series 2A Dormobile
Re: Just come back
Shiney! Needs Mud.
Re: Just come back
been a bit busy
going to pick up the white one tomorrow!
Re: Just come back
Wow, looks good.
What conversion have gone for? Lt77 or r380? What engine? I guess permanent 4 wheel drive transferbox?
Details details please
Re: Just come back
Lt77 plus 200 tdi. Engine sat on the original 6 pot engine mounts on chassis. LT77 has a removable cross member. Stage 1 axle to be removed from the green dormobile in due course and put onto this one.
Brakes to bleed (again) , steering lock to adjust (too one sided), turbo hoses to have jubilee clips on and one hose to replace, carpets, seats and wardrobe to re-install, gas to connect.
Probably a host of other things as well.
Re: Just come back
Is the stage one axle the front or rear axle? I guess if you use permanent 4 wheel drive you would need cv joints rather then the uj in the normal series front axle.
Did you have to move the gearbox x member or is it in the original place, just removable?
Sorry for all these questions, but I am planning and working out how to improve my Dora but still be able to make it original if it ever needs be.
Re: Just come back
The stage 1 is the front axle and has cv joints, however, several folk have run without stage one axles with no problems.
Leaving the engine on the 6 pot mounts means that most cross members are fine. Just the gearbox member needs removing and replacing with another one.
Gets a bit tight in the front though! (for radiator and cooling)
Re: Just come back
Looking very smart, Alex! Looking forward to seeing this finished!
