Good afternoon. A very prior PO has painted the internal surface of the roof a rather deep red. Surface looks in good condition but i would like to return it to a more conventional colour as it is somewhat dark
May i ask:
What colour should it be?
What are the suggested paint types for fibreglass?
Painting internal of roof
Re: Painting internal of roof
HI Mark
As far as I know, Series Dormobile roofs were not painted on the inside by the factory. Most of the roofs I have seen have not been paints, but have become very grubby over the years. Mine was just like that and also grubby on the outside as well.
I sprayed the outside with gelcoat and then wet flatted it back down again. I had plenty of white gelcoat left, so I sprayed the inside as well. I can highly recommend that as it looks great and is easy to clean.
I just used an oil-based white gloss on mine that looks really good and clean. Major improvement!
Thank you Gentlemen. I will research on the lines you suggested. Gel coats appeal as the outside is rather poor. Would be very interested to hear see of roof renovation approaches techniques and methods. Would like to avoid cost of professionald if possible.
Here's my efforts I also sprayed the inside of the roof which looks great
http://www.rms1.co.uk/lrcc/forum/viewto ... f=17&t=340
Two years on and the paint looks as good as it did on day one, I'm also pleased that no more cracks have appeared in the fibreglass. The only complaint I have is that the flexi paint hasn't worked on the inside of the striped canopy and has started falling off leaving bits on everything
