Silent Gliss
Silent Gliss
Anyone know where I can get the curtain header tape from please?
Re: Silent Gliss
I am a bit confused here, Alex. Which bit do you mean? Silent Gliss are still going and you can get pretty much everything still as far as I know...
Re: Silent Gliss
I'm guessing it's the same style as the Carawagon curtains? If so then it's probably this one:
http://www.silentgliss.co.uk/go/Product ... tion+/1025
You can also get the little sliders on ebay at some extortionate rate I think. Which may be useful if you only need a couple extra.
The tape that is sewn onto the fabric is pretty standard, and you should be able to get it from any fabric shop. Then it's just a case of putting the hooks onto the tape, and then hooking the curtain onto the silent gliss sliders.
Re: Silent Gliss
I thought you'd tackle the rust issues first AlexAlexB wrote:Anyone know where I can get the curtain header tape from please?
As Patrick said the tape is fairly standard, I found when doing my curtains that the first and last sliders kept falling off the curtain. I solved this by a drop of superglue on the first and last sliders then let the curtain tape string stick to it. I haven't had any problems since
Re: Silent Gliss
I will post a photo this evening.
The header tape has string loops at the top, which appears different, to my eyes, from ordinary tape
Re: Silent Gliss
Hope this makes things a bit clearer!
Re: Silent Gliss
The top string has been pulled taught to hold the sliders in place, it's normal header tape.
Re: Silent Gliss
Hi Alex
The Curtain tape used on Dormobiles is unique to the Silent Gliss runners and allows the curtain to fit directly to the runners without any hooks.
I bought all the bits I used in Barney from here http://www.volkswagencampercurtains.co. ... 0gliss.htm
Hope this helps
Hope this helps
Re: Silent Gliss
Very useful Mick, thanks
How is the spring getting on ?
I had tracked down the exact tape (from Silent Gliss) and am trying to negotiate a discount.
Re: Silent Gliss
Hi Alex
What are Silent Gliss charging? A very nice lady rang me from Gliss and was very helpful. If I looked back on my old PC, I could probably find her name. Not sure I bought directly from them in the end as I think the VW man was cheaper? The VW man wants £3 a metre for the loop tape.
