Carawagon roof & 110 camper body
Post by RMS » Thu Apr 25, 2013 11:14 am
Hi guys, this was spotted by Phillip (dudley):
Ebay 110 Camper Body & Carawagon Roof
It looks like the seller has removed the Carawagon part of the roof from a 109, cut the aperture in a 110 roof and fitted the Carawagon roof.
Not a quick & easy mod as the roof has to be reshaped at the front, but if anyone is looking for a 110 camper project, it might be worth it.
You could even remove the Carawagon roof section and refit it to a 109, but you would have to buy the whole lot which makes it a bit expensive just for the roof :shrug:
Hope it helps somebody.
Robin (& Phillip :tiphat: )
TheGreenlanecompany
Info: Traditional Greenlanin Fun with Series
Re: Carawagon roof & 110 camper body
Post by TheGreenlanecompany » Mon Apr 29, 2013 7:41 am
For the 110 a possible project...
But on a Series, things are not that easy as the windscreen is quite different..
Post by RMS » Mon Apr 29, 2013 9:25 am
As I said, you would probably have to cut a hole in a 109 roof and fit the Carawagon roof section into it.
Not as easy as just swapping roofs, but still do-able as it looks like that's what the seller has done to get it on a 110 roof :tiphat:
Still an expensive option though, unless you have a 110 to drop the whole lot on to :wink:
TheGreenlanecompany
Post by TheGreenlanecompany » Mon Apr 29, 2013 3:59 pm
:laugh: ... I happen to have a 110 HT that it could go onto..
However, Would only need the roof.
Somebody will be happy though when she / he buys it..
:tiphat:
Post by RMS » Tue May 07, 2013 12:32 pm
TheGreenlanecompany wrote::laugh: ... I happen to have a 110 HT that it could go onto..
:tiphat:
Well today might be your lucky day :cheers:
The seller has relisted just the roof, with a wooden bunk :shrug: starting at £199 :gold:
Ebay link HERE
Robin
Post by overlander » Sat Jun 29, 2013 3:45 pm
Re-listed again, I know somebody who should grab this....
Saga Lout
